Alternatives to PMS for charging leisure battery.
markxt
Post by markxt » Wed Sep 18, 2024 11:28 am
My PMS3 Managment System is faulty and does not charge the leisure battery (confirmed by mechanic). Replacement would be expensive. Otherwise PMS works OK. Presumably I could permanently connect the 240V supply to a small ('smart'?) trickle charger so the LB is charged whenever the van is hooked up? Advice appreciated - any specific chargers recommended (CTEK has been mentioned...)? An obvious alternative would be a solar panel which I may well fit later anyway. Thanks.
1998 2.0 L petrol. AFT.
Re: Alternatives to PMS for charging leisure battery.
Post by g8dhe » Wed Sep 18, 2024 11:42 am
Might be worth looking locally for an electrical repair shop - they do still exist! - most of the chargers can be repaired by a person with knowledge without too much difficulty, but I do admit the number of such shops has reduced dramatically in the throwaway society we have become!
markxt
Post by markxt » Wed Sep 18, 2024 2:57 pm
Agreed… I’m in the process of tracking such a thing down. However… with labour charges what they are, I think the cost of repair v new charger will be pretty similar. There’s always the chance that the fault is less serious than thought…
