Routing solar cables with aftermarket pop top
jospreckley
Post by jospreckley » Sat Aug 17, 2024 10:00 am
Hi folks.
I'm installing a solar panel to feed into the Bongo to charge an Ecoflow River 2 Max. My roof is an aftermarket one from Bongospares. Should I cut through the top of the roof into the pop top space to run the cables or go under the roof overhang and through the metal van body then chase the cables through the plastic trim? Both have potential to leak. What have others done? Thanks. ( nervous)
Re: Routing solar cables with aftermarket pop top
Post by g8dhe » Sat Aug 17, 2024 10:45 am
Welcome aboard!
On the standard AFT its drill thru into the area at the rear OUTSIDE the tent space and then because there are already electrical cables for operating the roof I passed the solar panel cables down the same rubber grommet thru the metal roof and into the internal roof space before feeding down into the rear cupboard where my controller is situated.
