Bongo Modification
Emily
Bongo Modification
Post by Emily » Wed Aug 07, 2024 9:58 am
Recently, I saw a modification case about Audi A6 on the forum, https://forum.revopoint3d.com/t/audi-a6 ... -usb/19065, which was really eye-opening. The owner used 3D scanning to turn the ashtray into a practical tool with a USB charging port, which made me want to do it. I also want to give my Bongo a big transformation!
My idea is to use 3D scanning to measure the internal structure of Bongo in detail, and then design some personalized functions, such as hidden USB charging ports or wireless charging pads, or even add a cool lighting system. This will not only make the car more practical, but also make it fun to get in the car every time.
However, this is my first time trying such a modification, and I don’t understand many things. So I especially want to hear your suggestions. If you have similar experience or know some related technologies, especially about equipment selection, data processing, design and printing, please share!
I am looking forward to your opinions and suggestions! I hope to communicate with you and see how to use these new technologies to make our cars more interesting! Thank you!
Re: Bongo Modification
Post by g8dhe » Wed Aug 07, 2024 11:15 am
Have you ever done any 3D scanning and printing before ?
You say "My idea is to use 3D scanning to measure the internal structure of Bongo in detail" do you mean the entire Bongo or just the ash trays and switch mountings ?
You might want to start small and be prepared to spend a lot of time and money getting the scanning and then the 3D printing all working together along with better software than what is normally supplied!
gilly99
Post by gilly99 » Wed Aug 07, 2024 7:28 pm
Hi... I'm an engineer, working in development including use of 3D printing. Also have a printer at home for DIY practical prints. If you've never used 3D scanners or 3D modelling software or 3D printers before, then that side of things is going to be quite challenging; a very steep, time consuming and frustrating learning curve - if you are really keen it might be better starting off by joining a 3D printing community and trying a few easier projects. Making cosmetically pleasing parts would steepen this learning curve significantly. You'd also be well north of £1200 for a most basic scanner and a fairly decent home printer. There are online digital printing services who can print your 3D designs. The temperatures inside a vehicle on a sunny day would drive use of polymers that are not so easy to print with, eg ABS or PP or PA, which require an enclosed/heated printer, although technology and such filaments are available for reasonable cost. You might get away with PETG, which is easier to work with and definitely good enough for prototyping something to start with. Anything is possible in this digital age, and pimping a cars interior is certainly achievable...... it just depends how much time and money you want to invest.
