Engine Temp - Haydn Alarm
NLB2024
Post by NLB2024 » Sun Mar 31, 2024 8:34 pm
So, just fitted my temp / coolant sensor from Haydn today, just bee for a run with it.
Drove about 20 miles @ 60mph - Rock steady 52 degrees c then came back at 70 mph and it topped out at 56 degrees c
Is that about normal? I have placed the sensor in t he recommended place per the instructions
Re: Engine Temp - Haydn Alarm
Post by g8dhe » Sun Mar 31, 2024 10:23 pm
Sounds about right.
NLB2024
Post by NLB2024 » Mon Apr 01, 2024 12:41 pm
Thanks :D
Post by g8dhe » Mon Apr 01, 2024 2:17 pm
Should say those temperatures are quite low, but if your a 2l petrol understandable, however a diesel can get a LOT hotter quite safely! Bear in mind the whole point of the sealed pressurised system is to raise the boiling point above the normal 100°C which allows more heat to be moved away so its quite normal to see a much higher temperature when the cooling system is doing its job!
NLB2024
Post by NLB2024 » Tue Apr 02, 2024 5:36 pm
This is on a 2.5TD
Post by g8dhe » Tue Apr 02, 2024 6:57 pm
If you have concerns then contact haydn callow on here as it was developed and sold via the forum at the start, and I do believe Haydn still comes on from time to time ... yes last on end of last year.
Post by Doone » Sat Apr 06, 2024 7:36 pm
Maybe related to the thermostat? it's possibly stuck in the open position or has been removed? You could check if the bottom hose starts getting warm within a couple of minutes of the engine starting from cold. With a properly working thermostat, it normally takes quite a long time to feel warm.
