Roof rack /bars AFT roof
micknick
Post by micknick » Fri Mar 29, 2024 2:07 pm
Has anyone got a roof rack or roof bars on an AFT roof mines a 2001
i have managed to find some on ebay but they are £299 plus another 45 for delivery and i was just wondering if there are any other options
around that i havent come across.
Re: Roof rack /bars AFT roof
Post by g8dhe » Fri Mar 29, 2024 5:24 pm
Yes quite a common add-on but be aware that the AFT roof changes shape over the years, later versions don't have the recessed drainage channels each side but the roof fixing/lifting nuts are in the same location hence the style of support needs to change depending on roof.
Also do make sure that nobody has loosened the nuts previously and possibly lost the fixing plate underneath which is hidden by the roof rails on the underside for lifting the AFT.
See here for some ideas, these are on the older type http://www.g8dhe.net/bongo_images/Roof_bars-rack
micknick
Post by micknick » Fri Mar 29, 2024 9:17 pm
thanks for the info, my roof doesn't have the drainage channels either side but there are what looks like 4
allen bolts,2 either side
