Parking sensors
Moderator: Ian
markxt
Parking sensors
Post by markxt » Sat Oct 28, 2023 9:33 am
Hello everyone. I'm sorting out our recently purchased Bongo and will soon be looking at head units (possibly Sony/Pioneer Apple CarPlay). I need reversing sensors that can be used with the unit (rather than need a separate display). Good visual guidance is essential (my partner is deaf). Most sensor kits use a separate display. Ideally I want to avoid cables but appreciate that a wired-in system may be preferable to wireless/bluetooth. Any info/opinion appreciated.
1998 2.0 L petrol. AFT.
Re: Parking sensors
Post by g8dhe » Sat Oct 28, 2023 11:29 am
Wired systems are much more reliable, there are so many devices these days using the shared 2.4GHz band that its not uncommon to suffer interference, also it has the advantage that wired systems can also be used as a rear view camera when driving, as opposed to merely when reverse gear is selected and the reversing light is powered.
markxt
Re: Parking sensors
Post by markxt » Wed Nov 01, 2023 9:14 am
Thanks for the advice - I'm gradually narrowing the search down, poss looking at a Pioneer unit as they make reasonably priced compatible cameras. The wiring aspect doesn't seem too complex. There is a lack of videos showing various cameras/parking systems in use although they seem to use the same 'guidelines' principal. It would be useful to hear from anyone who has had experience of any of these systems.
Fredalorian
Re: Parking sensors
Post by Fredalorian » Sat Dec 02, 2023 10:15 am
Please update when you decide as I'm interested in getting a parking sensor and reverse camera in mine and don't even know where to start.
Re: Parking sensors
Post by g8dhe » Sat Dec 02, 2023 4:45 pm
I've used a variety of cameras of the years here are some of the installations http://www.g8dhe.net/bongo_images/cameras/
markxt
Re: Parking sensors
Post by markxt » Wed Jan 17, 2024 3:48 pm
UPDATE!
As I have a Pioneer SPH-DA160 DAB unit I decided on a Pioneer ND-BC8 camera - not the cheapest but I assumed that compatibility would lessen the chances of any issues…
Installation was easier than anticipated and I confess to slight disbelief when I saw an image from the camera when selected from the DAB unit.
There is a live feed from the camera that has to be connected to a reversing light cable to enable auto switching to the camera when reverse gear is selected. The relevant cable was red and yellow and I traced it to under the trim on the left side of the passenger footwell, so this was the route I took the cable from the back of the DAB unit. The cable continued up to the plastic top trim to the rear of the Bongo where it exited with the wash-water tube and onto the top of the door. I decided to place the camera here because this was easier than putting it above the licence plate and also because this viewpoint is better for judging distance and to see the surroundings. I made a cover from an old 35mm film container and so far all is well. Parking guide lines appear automatically (if required) - these are part of the DAB unit rather than the camera - and can be easily calibrated to specific chosen distances.
Image quality is reasonable and as good as most (as far as I can tell) but I’m not sure why it can’t be even better bearing in mind the quality we have come to expect from phones. it is easily possible to wire the camera so that the image is always available, rather than just when in reverse.
Bongolian
Re: Parking sensors
Post by Bongolian » Sun Feb 11, 2024 12:15 am
Sounds really good, though I’ve gotta say, the most impressive thing is you ‘found an old 35mm film container’.!
Like many I suspect, I’ve gone through hundreds over the years but I’m damned if I could lay my hands on one now. 😁
Grimoh1
Re: Parking sensors
Post by Grimoh1 » Thu Jan 09, 2025 4:32 pm
Grimoh1 wrote: Mon Jan 06, 2025 11:18 am
g8dhe wrote: Sat Oct 28, 2023 11:29 am Wired systems are much more reliable, there are so many devices these days using the shared 2.4GHz band that its not uncommon to suffer interference, also it has the advantage that wired systems can also be used as a rear view camera when driving,For those interested in online gambling website it's crucial to choose reputable platforms that ensure secure transactions and fair playas opposed to merely when reverse gear is selected and the reversing light is powered.
Wired systems offer superior reliability, especially in environments crowded with devices on the 2.4GHz band, which can cause interference. They also provide the added benefit of functioning as a rear-view camera while driving, not just when reverse gear is engaged. This makes them a versatile option for continuous monitoring and enhanced safety. For those prioritizing consistent performance and flexibility, wired setups are an excellent choice over wireless alternatives.
ronandy
Re: Parking sensors
Post by ronandy » Mon May 12, 2025 6:49 pm
markxt wrote: Wed Jan 17, 2024 3:48 pm UPDATE!
I found this message from a while ago about how you installed a Pioneer reversing camera and would really like to pick your brains and get a bit more detail on how you did the wiring if possible. We are complete novices!
Many thanks,
Rona
Return to “Pimp My Bongo”
