Alternator Failed
Alternator Failed
Post by Ian » Fri Oct 20, 2023 8:03 am
Asking on behalf of John from Leeds who has a diesel Bongo. His alternator has failed completely and a garage 1 mile away have said they will install a new one. But is it safe (or even possible) to fire up the Bongo and drive the 1 mile to the garage?
With even my limited mechanical knowledge I know that the alternator feeds the belts which drive the waterpump which circulates the coolant. So is it worth the risk?
Re: Alternator Failed
Post by g8dhe » Fri Oct 20, 2023 9:25 am
On the diesel, the belt that drives the water pump is the same one as the alternator, so there will be no coolant flow! Not a good idea....
https://www.lushprojects.com/bongoparts ... mgno=.html
Post by Bob » Fri Oct 20, 2023 10:03 am
Geoff is correct, but if it’s only failed to provide charge, and the belts are intact, I recon it should be ok.
Post by g8dhe » Fri Oct 20, 2023 11:13 am
Good point Bob, was thinking belts had gone but may just be the alternator itself.
