Another AFT issue
Tsmsoccer
Another AFT issue
Post by Tsmsoccer » Fri Oct 06, 2023 12:32 am
Sorry another AFT issue
II cannot open the AFT I turn the ignition on and the brake light is showing on the dash but I do not get any beeping when I try and open the roof.
I have looked at previous posts and most relate to the brake light not working but mine does.
I have checked the switch behind the handbrake and fuses 12 and1 and all is working.
AS I said I cannot get the top to open or even the beeping sound any advise is greatly appreciated
Charlie
Re: Another AFT issue
Post by g8dhe » Fri Oct 06, 2023 8:37 am
Drop the roof switch (Up/Down) out and give it a clean, only when the first contact is made will the Beeping start, if the contacts are dirty then no contact and no beeping. See here https://www.youtube.com/watch?v=tX1SB0xoJOU
