Rear drivers side indicator not working
D n D & K
Post by D n D & K » Wed May 10, 2023 7:10 pm
hello all
rear drivers side indicator not working
Rear lights work passenger side indicator works i have checked bulb even swapped bulb for other side , checked fuses but i would have thought that effect lights a well
ive put a multimeter on and that shows current when indiactor is switched on
p plate 96 diesel bongo if that makes a difference
any help greatly received
gilly99
Re: Rear drivers side indicator not working
Post by gilly99 » Wed May 10, 2023 8:56 pm
Maybe try removing the rear driver's side light cluster and review the spider web inside. The little audible warning unit for reversing (if fitted) has caused me problems in the past, along with poor connections from towbar electrical connections etc.
Post by Bob » Wed May 10, 2023 10:14 pm
Worth checking the earth, maybe just run a new one.
Plus, is the brake light working?
Post by teenmal » Thu May 11, 2023 8:49 am
If its getting power and is well earthed it will be the bulb holder that is at fault .Try cleaning the contacts .
D n D & K
Post by D n D & K » Thu May 11, 2023 5:40 pm
hello all thanks so far for help
all rear lights are working fine ive tried cleaning contacts ,
taken relevant fuses out and checked those and cleaned those contact too
ive tried new bulbs and tried taking the one from other side that works and still nothing
