Electric Window help. Recommended Local garage/mechanic/electrical person
chris99
Post by chris99 » Sat Apr 29, 2023 7:32 pm
Hi, I'm in South Wales and was wondering big anyone could recommend somewhere that might be able to help with my most recent fault..
The passenger window has always been slow to go down, today it would not move at all, then it did, now it won't go up.
I'm not sure if it's an old wires issue or broken motor and need someone with some more skills than I have to look at it.
BongoTippMan
Re: Electric Window help. Recommended Local garage/mechanic/electrical person
Post by BongoTippMan » Sat Apr 29, 2023 7:45 pm
Can you hear the Motor trying to operate when you press the switch?
Post by g8dhe » Sat Apr 29, 2023 7:55 pm
Often the problem can be sorted to the drivers door wiring loom where it crosses over on the door hinge there is a repair kit available if that is the problem https://www.ebay.co.uk/usr/bespokeautoe ... ervices_uk
chris99
Post by chris99 » Sat Apr 29, 2023 9:32 pm
BongoTippMan wrote: Sat Apr 29, 2023 7:45 pm Can you hear the Motor trying to operate when you press the switch?
No, no noise at all
chris99
Post by chris99 » Sun Apr 30, 2023 7:20 am
This morning it just decided to work again!
Post by g8dhe » Sun Apr 30, 2023 9:07 am
This is typical of a broken wire in a door loom, the drivers door loom is the most likely, the wires break with all the flexing, they are inside a black convoluted tube and every time the door is used the wires flex until they start snapping. Hence the kit to replace all the wires as once they start going the others aren't far behind!
chris99
Post by chris99 » Sat May 27, 2023 1:46 pm
So I changed the wiring in the drivers door. Central locking and speaker now work. However passenger window still dead. What would be the sensible thing to test next?
Post by g8dhe » Sat May 27, 2023 2:39 pm
It can also happen in the passenger door loom, less frequent, but worth checking with a meter to see which loom is causing the problem.
Post by Bob » Sat May 27, 2023 5:29 pm
Problem with recommending someone local is we don’t know where you are. :wink:
Post by teenmal » Sun May 28, 2023 8:58 am
Check the passengers window switch on the drivers door control panel.
