Coolant pipes to rear heater matrix
adi999999999
Post by adi999999999 » Wed Mar 01, 2023 11:01 am
Hi, I have a diesel Bongo and need to replace the coolant pipes to the rear heater matrix, is there any reason these could not be made of copper? as I have the capability to bend and flange copper pipe
Re: Coolant pipes to rear heater matrix
Post by teenmal » Wed Mar 01, 2023 2:09 pm
No reason whatsoever , you could also consider lagging them.
You could also make them from rubber/plastic as long as the materials used are suitably rated.
adi999999999
Post by adi999999999 » Mon Mar 06, 2023 11:23 am
Thanks, on another note, how do you remove the plastic clips that hold these pipes?
jboocock
Post by jboocock » Fri Apr 07, 2023 9:11 pm
did you figure this out I see the nut and bolt just could not undo the clip or see how to undo it
Post by g8dhe » Fri Apr 07, 2023 9:28 pm
I've just posted a picture of the clip and its release catch on your original post.
