Removing a kitchen pod
chris99
Post by chris99 » Tue Feb 14, 2023 7:47 pm
Hi, I need to remove the interior of my bongo and am struggling with the kitchen pod. It is situated behind the drivers seat. Being very new to this, I can't see where to start with it. If someone could point me in the right direction I'd be very grateful..I'm hoping that once I get started Ill be able to see more of the fixings that are currently hiding from me!
Re: Removing a kitchen pod
Post by g8dhe » Tue Feb 14, 2023 10:30 pm
If its behind the drivers seat then it sounds like a conversion, the Kitchen pods that Mazda fitted are nearside at the rear.
If that is the situation then every conversion is basically different, it will depend on the company/person that fitted it. Often they are screwed into the plastic trim if it wasn't removed, and likely also into the flooring that will have been fitted, its case of get in with a torch and start inspecting!
chris99
Post by chris99 » Wed Feb 15, 2023 2:49 pm
Thanks, yes it is fixed in really well somehow.. I think I'm going to just have to continue to remove bits until I can get some access to somewhere it's attached!
