"Electrical bypass kit"??
Giffybongo
Post by Giffybongo » Wed Aug 10, 2022 3:50 pm
Hi folks,
Looking to find out what the part I need to get fitted that allows the electrics in the car to run without the engine or ignition on...I believe it may be called an "electrical bypass kit" or something similar.
Have just had the leisure battery isolated recently, so looking to add this as an extra.
Thanks! :D
Re: "Electrical bypass kit"??
Post by g8dhe » Wed Aug 10, 2022 4:02 pm
Normally called a Swap loom, it moves 4 - circuits across from the Starter Battery to a Leisure battery, Lighting and Backup supplies, Ancillaries (sockets and radio power) and if you have them the 2 Blind power circuits available as a kit if you don't want to make it yourself from https://www.ebay.co.uk/usr/bespokeautoe ... ervices_uk if the Swap loom is nor shown then contact Karl and I suspect he will put a kit togther for you.
Giffybongo
Post by Giffybongo » Wed Aug 10, 2022 4:17 pm
Thats brilliant,
Thanks for the reply, much appreciated! =D>
