Rough Idle / Vibration
Re: Rough Idle / Vibration
Post by Ian » Thu May 12, 2022 8:09 am
Sai, the problem here is that people will be afraid to click on the video link in case it's malware, especially as this is your first post. Can you post the video on a different platform (Youtube?) instead? Also put your physical location in your profile.
Post by g8dhe » Thu May 12, 2022 6:17 pm
Which petrol engine is it ? 2l or V6 I suspect a 2l. If its generating a lot of vibration in neutral then suspect one cylinder isn't firing so perhaps start with the ignition system and spark plugs, check the leads and the distributor.
Post by g8dhe » Sat Feb 10, 2024 10:33 am
These video's aren't visible and really we need more info like which of the three engine types your friend has there are 2 petrol types and a diesel, then the 3 different styles of roof.
There can be many causes for shaking and rough running!
Has it been checked for damaged tyres especially on the inner side, where its less visible, has it had the prop and drive shafts checked for broken supports and U/J's several of them have been reported recently, possibly caused by lack of maintenance and road state these days.
