LPG Underslung tank
jsforest1991
LPG Underslung tank
Post by jsforest1991 » Fri Apr 01, 2022 11:36 am
Has anyone mounted a LPG underslung torpedo tank on the N/S space (where a 4x4 would have the transfor box). I think people generally go for the donut instead of the spare type but I need a relatively small tank for the fridge and cooker.
Looks to be space but I wondering about the mounts people may have used.
Jarrod
1996 Bongo 2.5 Diesel AFT rear conversion with rear facing seat
Re: LPG Underslung tank
Post by g8dhe » Fri Apr 01, 2022 11:55 am
What are you referring to LPG for ? A diesel engine isn't the normally converted for LPG working ?
For Propane or Butane for cooking / heating then its normally the standard bottles and regulator.
jsforest1991
Post by jsforest1991 » Fri Apr 01, 2022 12:01 pm
Hi Geoff,
Yes I have a diesel so its not converting the engine to run on gas.
I would like to be able to carry more gas than I can today with a portable 2.75kg gas bottle. So looking at fixing a permanent tank to feed my gas appliances.
Also as space internally is at a premium, then I would have more cupboard space where my existing gas bottle is stored.
I know it all needs certifying, just curious if anyone has information/recommendations on mounting the tank.
Post by g8dhe » Fri Apr 01, 2022 12:27 pm
Can't say I have heard of it being done merely for cooking/heating as you will need to consider both filling requirements and also an evaporation unit as you will be feeding the actual LPG and not the already evaporated gas via a regulator to the equipment.
jsforest1991
Post by jsforest1991 » Fri Apr 01, 2022 12:52 pm
Yes plenty of people do it on other kinds of vans in particular and I can find specifically made mounting brackets for fiat, peugeot, VW, ford etc etc.
Yes, you install a filler point and the tank has a one way valve and auto cut off so you do not over fill (>80%) then a output valve that goes to your reg before going to your stop valve and appliances.
Post by Bob » Fri Apr 01, 2022 4:57 pm
I can see the sense of this, Bongos are small and every bit of storage counts.
Do bear in mind fewer garages are doing lpg so may be difficult to obtain.
Post by Bob » Fri Apr 01, 2022 6:05 pm
