Immobilising Bongo to prevent theft (waiting on TOAD unit to be fitted)
agentdagnamit
Post by agentdagnamit » Tue Dec 21, 2021 3:19 pm
Hi. There's been a bit of a Bongo crime wave in my area recently and I'm waiting for a proper immobiliser to be fitted. In the meantime, what's the best temporary solution? I only have street parking.
Can I remove safely remove the fuse for something like the ignition, ECU or fuel pump (and if so, in very simple terms, which are those!)?
Or is this a bad idea...?
cheers
Stu
sotal
Re: Immobilising Bongo to prevent theft (waiting on TOAD unit to be fitted)
Post by sotal » Wed Dec 22, 2021 12:43 am
I remember when I was moving some circuits over to the leisure battery, that when one of the fuses was removed the dash didn't come in and then it wouldn't start. Can't quite remember which though.
Fairly easy to get round though, but might slow them down I guess.
Disklok over the steering wheel is a relatively cheap solution or the pedal box locks.
Post by Bob » Wed Dec 22, 2021 10:22 am
Good tips above, and have a Google for 'battery isolator switch'.
Several types, anything to make it harder for the scum. :mrgreen:
Post by g8dhe » Wed Dec 22, 2021 11:43 am
Simple answer is yes! There are fact sheets available or look at what has been reported before, but it varies by engine type etc.
