Central locking on sliding door not working
TORPUSCAT
Post by TORPUSCAT » Fri Nov 12, 2021 5:40 pm
The central locking on my Bongo works fine for the front and rear doors but will not lock/unlock the sliding side door.
When the doors open there is a part with 5 pins in it which I assume makes the connection. 2 of the pins are permanently pressed in which I thought was the issue but having unscrewed and looked behind, there are wires connected to the 3 other pins.
Anybody with this issue previously.
TIA.
Vickie
Re: Central locking on sliding door not working
Post by g8dhe » Fri Nov 12, 2021 10:26 pm
The two pins that are pulled back are the locking solenoid, you don't want the door to lock whilst it hasn't fully closed, they don't make contact until the door is in.
Try cleaning the contacts with a kitchen scouring pad, plastic type not metal, as the contacts do get dirty.
After that it might be the little motorised door lock, which has been known to fail inside the door details on repair here or replace it;
http://www.g8dhe.net/bongo_images/Slidi ... /index.php
silverdreammachine
Post by silverdreammachine » Sat Nov 13, 2021 1:11 pm
I've had this too - I clicked lock on the key fob before the sliding door had fully closed and now the passenger side makes a noise when I try to lock and unlock. The boot and driver door still works; the passenger and sliding door don't. Have I broken it? TORPUSCAT any joy with a fix for yours?
SDM
TORPUSCAT
Post by TORPUSCAT » Sun Nov 14, 2021 9:36 pm
Thanks for the advice Geoff. I’ve cleaned the connections but still no joy.
Before I go unscrewing everything in sight on the door, where is the motor located? Do I have to remove the door panel?
Vickie
Post by g8dhe » Sun Nov 14, 2021 10:30 pm
Yes its behind the door panel, push the panel around the handle, fish out the clip on the back of the handle to release it - keep it safe! then into the door mech details here http://www.lushprojects.com/bongopartsm ... mgno=.html
