Remote Central locking
Hank
Post by Hank » Sat Nov 06, 2021 10:04 pm
Hello everyone!
New to all of this as the family and I picked up our first bongo last week :D It’s a 2002 model and I just wondered if it has remote central locking? We don’t have a fob, so I wondered if there is any way to tell if it has this feature, and if so can I buy a 3rd party fob and just reprogramme it?
Thanks!
Re: Remote Central locking
Post by g8dhe » Sun Nov 07, 2021 9:39 am
Unless you can find a remote fob receiver unit under the dashboard with extra wires run into the drivers door, then the only way is to look in the drivers door itself and see if a solenoid and receiver are mounted in the door itself. If there is then you need to identify the Make and model of the receiver and find a matching remote fob to pair with it, which might be a real pain!. Probably easiest to check in the door for a solenoid, and if not present (most likely) then buy a new setup single solenoid with fob receiver and matching fobs to install.
Brett_Sinclair
Post by Brett_Sinclair » Sun Nov 21, 2021 9:54 pm
Hi all
We finally bought our first bongo recently (many thanks to everyone on here who helped with advice etc)
It is a 2004 2.0 litre petrol aero and I am in a similar position to Hank. The seller only had one key and no key fob so I don't know if it has remote central locking.
Does anyone know if this was likely in this version or if there is a list somewhere that I could look up the model and what came as standard?
Thanks ...
Post by g8dhe » Sun Nov 21, 2021 10:18 pm
The remote fob was an option from Mazda and so won't show in the production spec. The only way to check is to open the drivers door and see if there is a remote fob receiver, if there is then you will have the fun of locating a fob to matchup which aren't strictly legal in Europe anyway they work on the wrong frequency! I would just bite the bullet and buy a remote system with a single solenoid to have installed in the drivers door.
Brett_Sinclair
Post by Brett_Sinclair » Sun Nov 21, 2021 11:15 pm
Thanks for that, I'll just stick with the key for the moment then I think :D
Robfv432
Post by Robfv432 » Sun Mar 13, 2022 7:10 pm
I’ve had a successful instal on an older vehicle using one of these units
There an auto start version for use on coke mornings as well
https://www.ebay.co.uk/itm/Universal-Re ... 635-2958-0
ever after.
Post by ever after. » Sun Mar 13, 2022 8:47 pm
Hey I've a one here that I got with my van but it's half broken as it only locks it.
Does this look like a standard remote or was it fitted afterwards and would it be a big job to get a replacement one?
https://flic.kr/p/2n8kYwY
TheLongRoad
Post by TheLongRoad » Mon Mar 14, 2022 8:12 am
Hi, the one in your photo is not the same as mine which came with a 2002 Bongo.
2002 Friendee 2.0 ltr Petrol.
ever after.
Post by ever after. » Mon Mar 14, 2022 4:43 pm
TheLongRoad wrote: Mon Mar 14, 2022 8:12 am Hi, the one in your photo is not the same as mine which came with a 2002 Bongo.
Ah OK thanks,
Forgot to mention my van is a 98 so maybe it's an older version or possibly even an aftermarket system :?
Hazzobongo
Post by Hazzobongo » Tue Mar 22, 2022 8:09 pm
Mines a 96 with it fitted from factory its just a key with two buttons, unlock and lock.
