BM715 Auto Box
BoolyBongo
BM715 Auto Box
Post by BoolyBongo » Mon Oct 18, 2021 10:06 am
I’m looking for an Automatic Gearbox (with its’ Torque Converter) for a 1999 2.5TD AWD. Gearbox code: BM715.
I’m in the Np13 area of South Wales and also looking for any advice where to get a gearbox, who can fit it and how to get my van there! 😟
oibaf
Re: BM715 Auto Box
Post by oibaf » Tue Oct 19, 2021 10:09 am
Someone else will know better than me for fitting etc but there are a few Bongo autoboxes on ebay (or was a few days ago).
Does the whole thing really need doing or is there a chance that it could be reconditioned by an autobox specialist? Alacrity here is the master of Bongo autoboxes if he is online!
BoolyBongo
Re: BM715 Auto Box
Post by BoolyBongo » Tue Oct 19, 2021 10:36 am
I’ve zero knowledge of automatic transmissions.
After doing a forum search, It seems refurbishment is the most expensive option, replacing with a 2nd hand unit seems the most wallet friendly option. Though a quote I received from BongoSpares of £825 plus £200 fitting seems excessive.
BoolyBongo
Re: BM715 Auto Box
Post by BoolyBongo » Sat Oct 30, 2021 2:34 pm
As an update. I had my 4x4 auto box replaced by Autocraft of Cardiff. Absolutely top notch friendly service, arranged for the Bongo to be transported the 25 miles to their knowledgeable garage.
Much cheaper than my quote from Bongo Spares and no £450 transport fee.
Re: BM715 Auto Box
Post by Bob » Sat Oct 30, 2021 3:36 pm
Really good to know.
Glad you're fixed. 8)
BoolyBongo
Re: BM715 Auto Box
Post by BoolyBongo » Sat Oct 30, 2021 7:50 pm
Bob wrote: Sat Oct 30, 2021 3:36 pm Really good to know.
Thanks. As a side note it turns out that the code wasn’t that important and that any 4x4 2.5TD auto box fits.
Propnut
Re: BM715 Auto Box
Post by Propnut » Sun Oct 31, 2021 5:50 pm
The difference between the early and later 4x4 boxes is the wiring and encoder on the shift lever on the side of the box. Alacrity swapped my later box for an earlier one swapping the later encoder to the early box too so the wiring harness was unchanged. Top work and very reasonable too, highly recommended. Bongo spares were talking about having to swap internals but they were probably thinking theyd use the later casing with encoder and fit the internals from the early box.
tuvster
Re: BM715 Auto Box
Post by tuvster » Mon Nov 08, 2021 7:33 pm
Hi bob just had fuel pump fitted now since i got it back the gears are acting up , going from 2nd to 4th hardly touching 3rd and ive started using the hold button a lot more. any ideas? thanks in advance
Re: BM715 Auto Box
Post by Bob » Tue Nov 09, 2021 10:40 am
Sadly no idea.
If you pop a rough location in your profile someone may recommend an auto box expert near you. 8)
Re: BM715 Auto Box
Post by rita » Tue Nov 09, 2021 11:13 am
Sounds like the throttle position sensor is faulty or out of adjustment, personally I would return to the supplier/fitter.
tuvster
Re: BM715 Auto Box
Post by tuvster » Fri Nov 12, 2021 8:02 pm
it was fine until fuel pump got fitted then came back like that , ok il ask him to look at that , thanks
