Running radio and blinds etc from leisure battery
Bongolia
Post by Bongolia » Mon Oct 04, 2021 10:16 am
Cold weather setting in I shall be sleeping downstairs and it would be nice to run the blinds from the bed. :D So want to swop over radio, blinds & fag lighter to the LB side of things I know there is info on the board but damned if I can find it. Can someone put up the subject link plz?
Re: Running radio and blinds etc from leisure battery
Post by Bob » Mon Oct 04, 2021 11:46 am
There's this old thread:
viewtopic.php?t=72124
Otherwise a Google of Mazda Bongo Swap Loom should yield results. :wink:
Post by g8dhe » Mon Oct 04, 2021 1:08 pm
There are kits available, if your not sure of what is required, make sure that your radio can either be REALLY turned off or use a kit designed to switch the radio correctly. https://www.ebay.co.uk/usr/bespokeautoe ... ervices_uk
