Headlights
tuttiweb
Headlights
Post by tuttiweb » Sat Sep 11, 2021 3:04 pm
Hi all,
I warned you there’d be more questions to follow…
When I switch my lights onto stage 1, dipped headlights, only the driver’s side lights come on, both front and back.
Twist on to stage 2 and all 4 lights come on.
Bulbs? Fuses? What are people’s general opinions on where I should head first please?
2000 Ford Freda
South Wales
Re: Headlights
Post by g8dhe » Sat Sep 11, 2021 3:29 pm
Which type of headlights do you have ? There is the standard H4 filament style or the HID bulbs style, also which year ?
It less likely to be a fuse problem as they do all come on but could be the actual headlamp connectors if the H4 style, although that doesn't explain the rear tail lights not coming on!
Rickster
Re: Headlights
Post by Rickster » Sat Sep 11, 2021 3:44 pm
If the lights is turned one click, it should put on the side lights front and back, second turns on dipped with high beam controlled by the stalk pushed forward.
Sounds like there is a wiring fault, the OP seeds to clarify exactly what position the switch is in, click 1 or 2 for dipped lights.
tuttiweb
Re: Headlights
Post by tuttiweb » Sat Sep 11, 2021 7:39 pm
Thanks for the responses.
It only switches on the lights on the driver’s (off-side) side of the vehicle when on 1st click, which sound to be sidelights.
On click 2, all 4 lights come one.
2000 Ford Freda
South Wales
Re: Headlights
Post by g8dhe » Sat Sep 11, 2021 8:27 pm
That sounds to be a wiring or grounding problem, the fuses and switching are common to the wiring loom/relays for all the sidelights and headlights.
The sidelights circuit however is a pain to work on as it extends all round as it also powers the internal location lights as well as the external vehicle lights.
tuttiweb
Re: Headlights
Post by tuttiweb » Sat Sep 11, 2021 8:44 pm
Great advice. Will get it sorted. Thanks.
(Apologies for auto-correct typo in earlier post.)
Out of interest, would this fail an MOT?
2000 Ford Freda
South Wales
Re: Headlights
Post by g8dhe » Sat Sep 11, 2021 9:35 pm
A fail, sidelights need to be working on there own right, without headlights as I understand it.
tuttiweb
Re: Headlights
Post by tuttiweb » Sun Sep 12, 2021 8:04 pm
Got the tester on this today.
Juice getting to the connector, so possibly a blown bulb coincidence.
Just need to work out how to change them now.
2000 Ford Freda
South Wales
oibaf
Re: Headlights
Post by oibaf » Mon Sep 13, 2021 4:46 pm
tuttiweb wrote: Sun Sep 12, 2021 8:04 pm Got the tester on this today.
They're easy enough really. Plenty of room under the bonnet. Pop off the rubber cover and look for the clip that holds the bulb in place. One H4 bulb per headlight. Old school!
Haven't done the rear ones so I can't help you there.
