Auto Transmission Pipes Replacement
spud350
Post by spud350 » Fri Sep 10, 2021 7:05 pm
Hi, advice needed please before the van accidentally goes on fire. I'm replacing the auto transmission pipes and have managed to disconnect the hoses and the 4 clamps holding them to the chassis but can't see how they come out.
With the shape of them I think they're the 1st thing attached to the van when it's being assembled.
No matter how much pushing pulling forcing I can't see which way they come out.
Has anyone changed them and what's the secret to getting them out and probably the other secret of feeding the new ones in without damaging them?? Much thanks, 🙏👀 ps it's for a diesel van.
pps. Before you get anything undersealed make sure everything that needs replacing is. That stuff makes the job even more worse than it already is.
Re: Auto Transmission Pipes Replacement
Post by g8dhe » Fri Sep 10, 2021 9:21 pm
Post by Muzorewa » Sat Sep 11, 2021 10:54 am
I didn't do this, I watched someone else do it - thanks Ady (Northern Bongolow) :oops:
From memory the pipes came out from underneath towards the rear, but it was jacked up quite high on the driver's side to make space for wriggling the pipes through. A fair bit of dismantling had to be done plus a lot of cursing, the mounting brackets snag everything and like you say, those pipes are probably the first thing in the assembly process with no expectation that they'd ever have to come out. While you're at it, do the coolant pipe that's alongside :wink:
Post by Northern Bongolow » Mon Sep 13, 2021 1:05 pm
It's a while ago, but from a bad memory I think we took out the radiator and battery etc to allow for the twisting / refiting of the new one, it's doable , front end up very high makes it easier and as said above do the coolant pipe at the same time.
Good luck.
spud350
Post by spud350 » Mon Sep 20, 2021 9:24 pm
What an absolute pig of a job that is. Fortunately I'll never have to do it again but I recommend taking it to a garage with ramps rather than DIY at home.
Post by Northern Bongolow » Mon Sep 20, 2021 10:29 pm
Look on the bright side, your far more intimate with your bongo .👩‍🔧
spud350
Post by spud350 » Tue Sep 21, 2021 9:51 pm
Yeah I now know I need a new cross member as well. #-o
