V6 losing power on hills
The Wanderer
Post by The Wanderer » Thu Aug 12, 2021 3:55 pm
Hi all
Does anyone have any suggestions about why my Bongo may be struggling a bit on steep hills?
The engine has only done 38k miles and generally feels fine but on any kind of steepish incline it needs my foot almost to the floor to sustain 60/65 mph. I've run this by a Bongo garage who agreed it feels maybe 25/30% underpowered compared to other V6 vans they know. Also the engine was compression tested and that was fine.
What should I look for? Anyone had similar issues? Someone suggested a partial blocked exhaust/catalytic converter might be the issue.
Any thoughts gratefully received.
'02 Charcoal Grey 2.5 V6 Full Side Conversion
Re: V6 losing power on hills
Post by g8dhe » Thu Aug 12, 2021 4:16 pm
Have you checked the gearbox oil level in the correct way ? See https://www.allansvehicleservices.co.uk ... +Check.pdf
The Wanderer
Post by The Wanderer » Thu Aug 12, 2021 5:07 pm
Hi Geoff
I haven't checked that but I will, thanks. I'm pretty sure the Bongo garage checked but I will take a look myself for peace of mind.
PedroBongo
Post by PedroBongo » Tue May 14, 2024 8:53 am
Did this power problem in hills resolve itself or what did you have done ? I have similar worse problem.
The Wanderer
Post by The Wanderer » Tue May 14, 2024 11:12 am
Hi PedroBongo
I had the cat replaced along with a couple of sections of exhaust, which was quite expensive but definitely improved performance. It's likely that the cat had become partially blocked through use of incorrect fuel, as in standard rather than super unleaded. It's probably best to get a trusted Bongo garage to take a look and give it a test run to see what they think. I had a few people test drive mine who were able to make a comparison with other V6 Bongos they serviced etc. There was nothing else that seemed likely to be causing the issue so eventually I had to take the plunge even though it was a bit of a financial hit, even for an aftermarket cat. Good luck with resolving it.
