Hi All, For info, all the components for the well known TM2 temp alarm with oil level alarm have been used up. The TM2 has been replaced by the TM1 temp alarm also with oil level alarm. The TM1 does everything just the same but the red readout has been replaced with with a normal black on white lcd display, the oil wire is longer after taking note of your feedback comments. Size is unchanged and we can still supply with a built in Low Coolant Alarm if required. If you really want a red display, get your order in now as we have only 4 TM2s left.
The TM1 has upgraded components and come with the renowned Haydn Alarms after sales service.
TM2 superseded by TM1
- haydn callow
