It looks like I may be finally getting my hands on a Bongo (2.5 TD). However, before I sign on the dotted line, so to speak, I wanted to ask a few questions.
- The van has just passed through it's CVRT/MOT test with no advisories, all good there.
- A diesel leak I spotted when I checked it over has been sorted with a new gasket on the pump.
- There was a small crack in the engine oil sump, which I had not spotted, this has been welded and the engine oil and filter replaced.
However there are two things which bother me a little.
- The seller says that the front-left driveshaft needs to be replaced, when you drive it you can hear a "ding ding ding" when turning sharp left or right. I've done a search on the forum and have seen others have this issue but it seems to trace back to CV joints and stuff. The seller has said it would be easy to remove the front drive shafts to avoid this. I know this isn't recommended on here.
- The fuel gauge doesn't work, although I know there are sometimes easy fixes for that. Are there cases where the fuel gauge is just broken forever?
Mind if I throw a few pictures here to see if anyone spots anything from the the underneath that I've completely missed?
The inside is nice and tidy, nice rear conversion on it.
So....based on all of that, should I be worried? Is it mad to go and buy this?
