drivers door hinge pins
turfite9999
Post by turfite9999 » Fri Apr 09, 2021 10:47 am
Hi guys does anyone know the size of the drivers door hinge pins and bushes please, dont know if I can get standard or generic ones.
:oops: many thanks
In desperation
Tony
Re: drivers door hinge pins
Post by g8dhe » Fri Apr 09, 2021 10:59 am
Never heard of anyone needing to, the pins aren't shown as separate items on the parts diagrams either, just the entire hinge.
Post by rita » Fri Apr 09, 2021 11:24 am
If you knock out the pin and measure it you should be able to get new pins and bushes from ebay or amazon etc .
example
https://www.ebay.co.uk/itm/Bushing-Kit- ... ZgQAvD_BwE
turfite9999
Post by turfite9999 » Fri Apr 09, 2021 12:23 pm
Thank you guys for your reply, I`m almost sure its the pins but dont want to take off wing before buying replacements, I think you have to take off wing to knock them out and measure?
Thank you guys
Post by rita » Fri Apr 09, 2021 9:52 pm
You dont need to take the wing off, just remove a hinge knock the pin out and measure pin , put the pin back in a refit hinge order kit .
turfite9999
Post by turfite9999 » Sat Apr 10, 2021 9:27 am
Thanks Rita Ill have a go
