Hi Guys hope you are all well,
I am making some lets say top units or overhead units/cupboards above windows has anyone any ideas on how to fix them to the van please
Thank you
Tony
units above side conversion
- turfite9999
- Bongonaut
Re: units above side conversion
often use the high level handgrip mounting positions as the main fixing and then additional screws are added in some designs I suspect to ensure stability at the ends.
- turfite9999
- Bongonaut
oh yeh thats a good idea Geoff i`ve lots of stuff going on with bongo and thank you again
Tony
Tony
Hello
I used the high level hand grips but avoided drilling any holes by using a 30mm × 1000mm strip of 90 decree aluminium . This I placed between the roof of the van and the floor of the aft. With my cupboards fixed by the hand grips it cannot move forward so the purpose of the bar is just to stop it dropping. Works perfectly without the need for any drilling.
- turfite9999
- Bongonaut
thank you for that Roy it is appreciated
