Power steering issues
Shak130
Post by Shak130 » Tue Jan 26, 2021 5:01 pm
Hi All,
Given the recent weather i have had some great fun in the bongo! 4 wheel drifting and dognuts 🤪 all in a private car park of course. Unfortunatley my power steering is now playing up :roll:
At idle stationary i have no power steering. When i rev it to 1500rpm power steering works. Its parked up atm but is my daily so i really need some help please..
I have checked the belt and fluids all ok. I have oiled the uj in the steering arm...
How do i determine if its a steering pump or rack issue?
Its a n reg diesel
Help advice would be appreciated
Re: Power steering issues
Post by g8dhe » Tue Jan 26, 2021 6:50 pm
The fact that it works at higher revs might suggest that the pump is having a problem, rather than the rack itself assuming there are no leaks ?
Post by rita » Tue Jan 26, 2021 7:18 pm
Shak130 wrote: Tue Jan 26, 2021 5:01 pm Hi All,
Its a n reg diesel
Your best bet is to check the actual PS fluid pressure, there is a relief /bypass valve on the pump it could be sticking .Please leave the dognut alone.
Shak130
Post by Shak130 » Thu Jan 28, 2021 11:11 pm
Thanks i will check the pressure. Lesson learnt never abuse your bongo =D>
