Quick release oil sump plug
jsforest1991
Post by jsforest1991 » Mon Jan 18, 2021 3:14 pm
Has anyone ever fitted an quick release oil sump plug? I have a 1996 2.5 diesel I bought last year. I changed the oil when I got it and was thinking of doing every 5000 kilometers. Hence trying to make it as easy as possible.
1996 Bongo 2.5 Diesel AFT rear conversion with rear facing seat
Re: Quick release oil sump plug
Post by Bob » Mon Jan 18, 2021 4:44 pm
Not fitted a plug, but I use a Pela Pump for the intermediate oil change.
Some will say it doesn't get every last drop out, but it'll do for me. 8)
Welcome to the Forum. :)
jsforest1991
Post by jsforest1991 » Mon Jan 18, 2021 4:53 pm
Thanks Bob, I'll take a look.
Post by rita » Mon Jan 18, 2021 7:13 pm
Quick release plugs are ok, just watch the ground clearance Pela pumps might be handy for ATF if no plug but I dont rate them for engine oil change, it takes seconds to remove the SP.
philsteward
Post by philsteward » Mon Jan 18, 2021 9:01 pm
Hi, this is what I've used on my Land Rover before now...
https://www.difflock.com/drain-plug-m14-x-1-5-t11-5
Coupled with this makes oil changing not only quick but you can do it whilst wearing your whitest shirt!
https://www.difflock.com/drainer-small-250mm
Does anyone know the thread size and pitch?
1996 4WD 2.5d full side conversion with 6 seats & AFT
Post by rita » Tue Jan 19, 2021 12:16 am
philsteward wrote: Mon Jan 18, 2021 9:01 pm Hi, this is what I've used on my Land Rover before now...
M14x1.5 Pn HE0310404
jsforest1991
Post by jsforest1991 » Tue Jan 19, 2021 11:25 am
Thanks both
jsforest1991
Post by jsforest1991 » Tue Jan 19, 2021 5:52 pm
For anyone searching this -
Searching for the thread size kindly provided I searched eBay and found it fits an MX6
Sump Plug Oil Drain HE0310404 For Mazda 2 3 323 6 626 MX3 MX6 RX7 B-Series
Going to the femco.com site and entering - MX6, 1996, 2.5
Lists these as options
https://www.femco.com/compact-90-drain- ... 14x15-t12/
https://www.femco.com/compact-drain-set ... 14x15-t12/
https://www.femco.com/compact-sb-7090010155-m14x15-t12/
All three if the search works - https://www.femco.com/products/?product ... ngine=9336
