Fireproofing the walls
Chamomile
Post by Chamomile » Wed Jan 13, 2021 8:39 am
Hi!
I am a tinker and a mechanic both jobwise and hobbywise. I love tinkering with this and that and I decided to install a small workbench in our Bongo. It is just me and the hubby and he is fine with that idea. I know where and how to put the workbench but I need some advise as how to secure the surroundings. What kind of disposal bin should I have and how to cover the walls and nearby floor to be fireproof. I am not going to burn anything but I use a welder, so you know. All tips are welcome!
Flanners
Re: Fireproofing the walls
Post by Flanners » Wed Jan 13, 2021 9:40 am
:shock:
Post by Bob » Wed Jan 13, 2021 9:57 am
I'd get a Workmate, replace the ply with metal, and weld outside. 8)
If it needs to be more stable I'd make a bracket and brace it to the tow bar.
Post by Northern Bongolow » Wed Jan 13, 2021 10:33 am
Fire / heat resistant board, the type they use to surround log burning stoves, or make register plates for the flue to go up through a combustible roof. Thin and light.
Available from stove accessory stores.
