Middle seats turning to face the rear
TBULLDOG
Post by TBULLDOG » Sat Jan 09, 2021 11:15 pm
Hi all
I want to turn the middle seats around to face the rear but have the short rail set up, how do i remove the runners to turn them around so the seat mechanism will still work ? (yes I removed and replaced the seat to find the mechanism doesn't work :roll: :roll: .
Do I need to remove them from the floor or is there an easier way???
Terry
Re: Middle seats turning to face the rear
Post by Bob » Sun Jan 10, 2021 12:04 am
There is a very good Fact Sheet on this in the Members' Area.
The job is quite simple, but you will have a gap between the front and middle seats when they're folded down.
This won't be an issue if you're using it as a day van, but will need to be addressed if you plan to sleep in it. :wink:
