Heater issue - only works when set to 32c
agentdagnamit
Post by agentdagnamit » Wed Jan 06, 2021 3:44 pm
Hi. My 2.5 petrol Bongo (2000) has a strange heater issue. The front and footwells only blow hot when the digital heating control is set to 32c. The window vent seems to blow correctly, ie according to the value set.
The AC works correctly and air blows as controlled by the fan button.
Any ideas?
Re: Heater issue - only works when set to 32c
Post by g8dhe » Wed Jan 06, 2021 4:01 pm
Try cleaning the sensor, often cures the problem for many, see here for details https://www.igmaynard.co.uk/bongo/forum ... =3&t=52877 You need to clean the front of the module and also inside as its often jammed up inside as well.
Flanners
Post by Flanners » Thu Jan 07, 2021 9:33 am
https://www.igmaynard.co.uk/bongo/forum ... hp?t=27682
Notwithstanding faults, the heating system seems to work in a quirky fashion and seems to actually blow differing temperature air from different vents when at certain set temperatures. Detailed in many posts and the translated handbook.
agentdagnamit
Post by agentdagnamit » Fri Jan 08, 2021 2:39 pm
Thanks. I removed the sensor and gave it a clean. One of the 4 'sprongly' springs had detached from the main body of the sensor, so I soldered it back on. But soldering isnt my strong point, so not sure if I made a proper connection, it's pretty fiddly. Any idea if only having 3 of the 4 sensors connected could could this issue?
Next, I'll check all the connections by the drivers left foot, they seem OK.
Definitely getting air of the correct temperature from the windows and foot vents, just the dashboard vents seem to have the issue.
Post by g8dhe » Fri Jan 08, 2021 10:27 pm
Yes the Jap's don't like hot air blowing in the eyes, so hot air only comes out from the footwell or on the windscreen.
