Fitting diesel heater in v6
stephens1971
Post by stephens1971 » Thu Dec 03, 2020 5:19 pm
Im looking to fit a diesel heater under the front passenger seat in my 1999 v6 i have looked at the members fact sheet for newshape vehicles but this is for a diesel i seem to have quite a lot of electrical wiring where you normally fit the heater can this just be moved or is it not possible to fit hete on v6 hopefully attached pic
Re: Fitting diesel heater in v6
Post by g8dhe » Thu Dec 03, 2020 5:36 pm
Most people just move the items inboard of the supports I gather see here for various pictures for both 2l and V6 http://www.g8dhe.net/bongo_images/Heate ... ol_bongos/
stephens1971
Post by stephens1971 » Thu Dec 03, 2020 6:03 pm
Hiya Geoff
Thats great thanks for the pictures a big help
Thanks Stephen
cwilliams255
Post by cwilliams255 » Thu Dec 03, 2020 9:22 pm
Moved ignition coil as far forward as I could, egr tank as far backwards as possible and wiring a bit. Egr tank needed slightly longer hoses I used standard fuel pipe. If you’re routing your ducting to sliding door I reckon you can just move the tank
stephens1971
Post by stephens1971 » Fri Dec 04, 2020 9:07 am
Thanks for the pictures will be a bid help going to give it a go over Christmas
Stephen
Jackdoor125
Post by Jackdoor125 » Wed Feb 07, 2024 10:23 pm
Could you please describe the bracket u used for the fuel canister?
Jackdoor125
Post by Jackdoor125 » Wed Feb 07, 2024 10:55 pm
Hi would like to know the configuration of the fuel bottle bracket for the V6
Jackdoor125
Post by Jackdoor125 » Wed Feb 07, 2024 10:56 pm
What is the configuration of the fuel canister bracket?
Deep_Lock
Post by Deep_Lock » Sat Apr 19, 2025 11:10 am
I’m just in the middle of doing mine did you ever managed to find a solution?
Post by g8dhe » Sat Apr 19, 2025 11:22 am
Not sure there is a bracket, I seem to remember the ones I've seen just rested in the gap itself.
