Bak-Rak Rear Storage
espressobongo
Post by espressobongo » Fri Nov 13, 2020 3:57 pm
Hi.
I'm about to invest in a base rack and box from these people to carry camping stuff (in the hope this blasted virus thing is over soon and I can head off in the Bongo again, I'm suffering withdrawal symptoms badly....)
My question is will I need to also fit a number plate board with electrics etc.? If so, any idea of the cost of these things and can I get someone to do it, being useless at such things myself?
Any advice or experiences much appreciated.
Keep smiling! :D
Frankie.
Re: Bak-Rak Rear Storage
Post by g8dhe » Fri Nov 13, 2020 4:20 pm
Yes you will as its rather likely that you will obscure the existing number plate as a minimum and possibly the lights as well depending what you fit on the rac! Most of the local towbar installers will give you a quote if you give them a ring, most will also come to you.
cwilliams255
Post by cwilliams255 » Fri Nov 13, 2020 5:28 pm
Fitting a decent towbar to the bongo is a bit of faff especially if it’s seen any rust in its 20 years +. The good ones require you to drill through chassis rail on near side to provide extra support - problem is that there’s only about 20cm clearance for the drill and bit is 18mm diameter- not many short 18mm bits around. I had to use a 90 degree adapter
TLDR get someone to do it for you :D
Flanners
Post by Flanners » Sat Nov 14, 2020 11:25 am
If you cycle, then a Thule 973 rack with the Thule Backup 420l box is a great multi use set up which clears the lights and number plate. I have one it works very well for my needs.
espressobongo
Post by espressobongo » Sat Nov 14, 2020 5:06 pm
Thanks for the advice all. I've got a local man set up to put the toolbar on, I'll talk to him about the board as well then.
Cheers.
Post by Bob » Sat Nov 14, 2020 5:15 pm
This is the kind of thing:
https://www.ebay.co.uk/itm/7-pin-PRE-WI ... 1480671333
Fairly straightforward, and don't use Scotchlocks. :wink:
Post by rita » Sat Nov 14, 2020 6:21 pm
Bob wrote: Sat Nov 14, 2020 5:15 pm This is the kind of thing:
Hi Bob , why not use Scotch Locks ?
Post by Bob » Sat Nov 14, 2020 7:38 pm
They are prone to cutting the wires and water ingress, but personal choice.
Colin
Post by Colin » Sat Nov 14, 2020 9:15 pm
Can I put a tow bar box on if I have a Thule 973 fitted?
Post by rita » Sat Nov 14, 2020 10:49 pm
Bob wrote: Sat Nov 14, 2020 7:38 pm They are prone to cutting the wires and water ingress, but personal choice.
Thanks for the info, what would you recommend ?
Post by Bob » Sat Nov 14, 2020 11:31 pm
I'd recommend an auto electrician.
Post by mikeonb4c » Sun Nov 15, 2020 11:05 am
rita wrote: Sat Nov 14, 2020 10:49 pm
Bobs right about Scotchloks, whoever fitted the towbar to mine (a garage i think), i started to get o/s tail light bulb blowing. Not problem since i removed all scotchloks and soldered all the connections. I thought of getting a bakrak wsy back then but on reflection I'm glad i didnt. In the years since i've read of towbars sagging due to towball mounted loads. I'd go down the Thule/Fiamma tailgate rack/box route or - better still i think - a lightweight trailer with hard top if you've somewhere to keep it.
Post by mikeonb4c » Sun Nov 15, 2020 7:59 pm
Hi Rita. I found soldering has worked well for me, but I know you are very savvy on car mechanics and I'd love to hear of other suggestions that would be easy to do and not give trouble like Scotchloks (which certainly gave me trouble :-( ). Soldering produced a good result for me (you have to make sure the soldered connections don't suffer fatigue vibration, unlikely but easy to plan for anyway) but it is perhaps not for everyone.
I don't drop in on BF as regularly as I used to. Great to see you're still here and keeping people guessing! 8)
