I think I have read through most entries on thermostats, but I'm not getting answers to my questions. My thermostat is jammed open I suspect, and I'm concerned that I will need to bleed the whole coolant system when I change it.
If not, how much coolant will I loose roughly during the procedure, Is that known so I can have it ready made up and can I top it up from the header tank without needing to see saw bleed the system? I don't mind putting the work in, and my new to me Bongo has no history, however appears to have a had a new radiator fitted recently so don't see the point in a full flush and bleed. I'm currently 'pink lint' (skint, or of limited finances). Not that that's a new situation to me, but I'm having to be careful what I spend my money on at the moment. I see you are all very helpful and friendly so I look forward to some great advice, and I wait in anticipation for your replies.
I do have a rough idea how to do it... move the dip stick tube out the way by means of removing the 10mm bolt that secures its position and then remove the 2 bolts into the thermostat housing. Replace the thermostat with the mouse ear towards the driver door.
Any corrections or more nuggets of gold would be appreciated. Pictures or videos of someone doing the job even better, though I've hunted and couldn't find one.
After this job I'll be replacing the Rocker cover gasket so will be dismantling the center console for access I believe.... anyway let me not get ahead of myself. I really look forward to hearing from you.
