Centre light unit dim
phillips321
Post by phillips321 » Fri Sep 11, 2020 1:36 pm
Hi all,
I've just picked up a new to me 1996 Mazda Bongo Camper and it has a few issues that I'd like to tinker with to sort. So apologies for the multiple posts, I just thought it would be easier to track this way.
My centre light (not the ATF light) is very dim, how can I get access behind the light potentially change the bulb and also measure the voltage that's reaching it?
Thanks in advance
cwilliams255
Re: Centre light unit dim
Post by cwilliams255 » Fri Sep 11, 2020 1:55 pm
If it’s the rear cabin light you’re talking about, carefully the plastic clear cover with small screw driver, then remove the 4 screws holding it to roof, you can then access the connector. The connector should be 12v, ground and switched connections. It’s common to replace the bulb with LEDs with some slight modification (a forum search should help)
Post by g8dhe » Fri Sep 11, 2020 8:24 pm
For replacing the fluorescent tube with LED's see below;
There are two styles the older straight tube variety see these pictures;
http://www.g8dhe.net/bongo_images/repla ... ight_tube/
and the more recent "U" tube style;
http://www.g8dhe.net/bongo_images/repla ... cent_tube/
Post by Doone » Mon Sep 14, 2020 6:36 am
Thanks Geoff, its now been added to FAQs. :)
