Front washers not working...
BongoBongo123
Post by BongoBongo123 » Wed Sep 02, 2020 5:25 pm
I am pulling the left side stem forwards and getting the intermittent wipe but no screenwash.
No motor sounds evident (but I am getting motor sound from the rears), checked tank (full), no leaks that can be seen under bonnet. Was working on fuse box near right knee a few days ago fitting coolant alarm. But fuse intercepted seemingly not the same as indicated here, no loose wires spotted (check that fuse row 2, 7 from left 20 amp - not blown)
viewtopic.php?t=41935
Any other obvious things to check for before further deeper checks ? (not sure where the motors are actually)
cheers
They call me light foot.
Re: Front washers not working...
Post by Bob » Wed Sep 02, 2020 5:32 pm
The pumps are fitted into the washer bottle with gromets.
It's not difficult to remove them and I'm pretty sure you can swap them over to check operation, although once out this would be easy on the bench.
The pumps are cheap enough on Flea Bay. :wink:
Just one seller:
https://mazdabongo.com/product/mazda-bo ... 5-onwards/
Post by Northern Bongolow » Wed Sep 02, 2020 7:30 pm
Don't know how to post links via phone but of you search service and windscreen and washers by author northern bongolow you will get a how to with pics on how to strip and clean etc.
Post by Bob » Wed Sep 02, 2020 7:38 pm
Post by Northern Bongolow » Wed Sep 02, 2020 9:50 pm
🕵️that's the one, thanks bob 🐼
Post by Bob » Wed Sep 02, 2020 9:54 pm
It helped me sort our Bongy. \:D/
BongoBongo123
Post by BongoBongo123 » Thu Sep 03, 2020 2:23 pm
Thanks.. I presume if front motors were working I would be hearing a "whiiirrrrrrrr" as per the rears, funny how you don't notice such things until you need to. Thanks for the info this should be helpful, not looking forward to this one tbh.
I guess need to work out how to get the fluid container out first.
Post by Bob » Thu Sep 03, 2020 3:15 pm
I can't remember how it came out, but it wasn't difficult, just a case of MK1 Eyeball. :wink:
May be tight if you have a leisure battery, but that can always come out, too.
cwilliams255
Post by cwilliams255 » Thu Sep 03, 2020 11:23 pm
Pretty easy to remove the fluid bottle, just a couple of 10mm bolts, just be careful once they’re out to unclip the hose runs as you pull it up carefully - as mentioned definitely easier with LB and tray out of the way
BongoBongo123
Post by BongoBongo123 » Fri Sep 04, 2020 2:22 pm
Great thanks, all info helpful.. I cannot help but wonder if something was kncoked when I behind the knee fuse box ( I was quite cautious as I was aware not to pulll things about too much)... but it does not seem to be the case.. wires look in tact and also the relevant 20 amp fuse seems to be fine. (As I gather the wipers are on the same fuse as the screen wash motors and the blades are moving fine)
So most likely is connector, pump or switch maybe, will have to go through it on a quiet day.
BongoBongo123
Post by BongoBongo123 » Sat Sep 05, 2020 8:54 am
I was wondering if there are 2 seperate switches on the stem for washer and wiper or 1 switch that activates both.. I am rather hoping it is not the stem switch. (Wiper works just not the washers jets)
Post by g8dhe » Sat Sep 05, 2020 9:13 am
There independent contacts within the stalk, but I don't think they are a separate module as such;
and the next 2 page as well.
JulesMartin
Post by JulesMartin » Sat Sep 05, 2020 9:23 am
When you get to the pump after taking out the washer bottle you can substitute the connections to test the wiring to the pumps. if you switch connectors and the front pump works when operating the rear washers then it must be the front pump wiring and visa versa if it still doesn't work when plugged into the rear wiring it must be the front pump that's not working. if I remember the pumps are different and cannot be interchanged although you could, by switching the wiring and pipework use the rear pump to wash the front screen as that is the more important as a temporary fix. when I pulled all mine out it was the front pump that was seized. it is an easy enough job to strip it down and un-seize it. they place the rear pump above the front pump so that when the rear pump runs dry you know you need to top up the reservoir before the front/lower pump runs dry.
Martin
Post by g8dhe » Sat Sep 05, 2020 10:38 am
The connectors for the pumps are polarized! Yo can't connect the rear wiring to the front pump or vice-a-versa!
BongoBongo123
Post by BongoBongo123 » Sun Sep 06, 2020 11:27 am
Great... thanks Geoff and all, useful (although I was hoping there was just 1 switch so it seems the stem switch for washer, I cannot rule it out from the outset.) Will start at tank end first after double checking fuse again to be 100pct sure. Just have to work through it bit by bit I guess.
