Dim headlight - ground issue?
BongoBear
Post by BongoBear » Tue Sep 01, 2020 7:23 pm
Hi all,
The nearside headlight on my Bongo is a bit dim (along with its owner :lol: )
It's noticeably dimmer than the offside one both on dipped beam and full beam (doesn't appear to get any brighter at all, although the offside is fine).
After a bit of searching online I think it might be an issue with the ground connection? Has anyone else had this problem? And where should I look for the right wire/connection to poke/scrub???
Thanks in advance!!
Re: Dim headlight - ground issue?
Post by Northern Bongolow » Tue Sep 01, 2020 11:22 pm
Usually it's the plug on the back of the bulb, try that first.
Post by Bob » Tue Sep 01, 2020 11:27 pm
Good point, Ady.
These are worth a look:
https://www.ebay.co.uk/i/173975467855?c ... LMQAvD_BwE
Plenty of other sellers.
sotal
Post by sotal » Tue Sep 01, 2020 11:41 pm
Mine was the plug, wasn't too hard to change. I seem to remember doing it in the dark one evening.
It did require a bit of soldering IIRC and was a little limited on space. I took the headlight unit out.
I bought a pair of plugs figuring the offside would need change soon after but a couple of years on it still seems perfect. The replacement plug was an instant fix and I could see where the old one had being getting hot.
BongoBear
Post by BongoBear » Wed Sep 02, 2020 10:02 am
Thanks all, will have a closer look later today!
