I've a newshape 53 plate diesel bongo.
I'm trying to locate the throttle position sensor, but it seems to be in a different place to the older models. Attached is a piccy of my driver's side engine bay, can someone spot the TPS sensor for me?
Confused!
Rick
where is throttle position sensor
rocketeeer
- Bongonaut
Re: where is throttle position sensor
Just guessing, is it on the throttle peddle, not had owt to do really with the new ones. Lol.
Or that little box on the pump pictured may be a modern equivalent.
rocketeeer
- Bongonaut
Thanks,
There is something on the throttle pedal - looks like a syringe. I thought it was just a kick-down switch but now you've got me thinking!
rocketeeer
- Bongonaut
Found it above the pedal: the 'syringe' thingy is just a switch - presumably to check you don't have your foot on the gas when you start the engine.
It looks similar to the old-shape throttle sensor, just re-located.
Does anyone have an electrical description for it? Which sensor is it in the wiring diagrams, is it 'X20?'
