It has been a while but the bongo is still great
sotal
Post by sotal » Fri Aug 14, 2020 9:58 pm
It has been almost a year since we last camped in the bongo, but just had a lovely week away. (The bongo is a daily driver though, and has been quite a workhorse this year!)
The campsite was geared up to be covid safe, so was running a 50% capacity but it did mean there was no showers or toilets too.
We took the Porta potty but the wife had never liked carrying it in the bongo so I made some brackets to attach a large box that we had for keeping wellies in, onto the bike rack. Ended up with the toilet, the chemicals, 4 fold up chairs, the breathable awning carpet and the BBQ in the box.
The shower ended up being a 5L water bottle with holes cut in the lid. Quite refreshing with the heat we had!
Now I just have to worry about the MOT that is booked in this week.
I know the exhaust needs a section replacing, and I have the section to go in. I'm hoping the rust is all superficial as it seems to be a constant battle. Various clunking noises at the front seem to be getting louder too. I'm reckoning the brakes might be getting a bit low too. Could be a busy week ahead!
Re: It has been a while but the bongo is still great
Post by Bob » Sat Aug 15, 2020 7:34 am
We've used a watering can as a shower in the past.
Almost fill with cold, add a kettle of hot, and it's just enough for two if you're frugal. 8)
Post by Northern Bongolow » Sat Aug 15, 2020 9:01 am
Just to be accurate,
Was it a wide rose for two to stand under, or a partly blocked rose that took a while to empty or a very large can.😁
Post by Bob » Sat Aug 15, 2020 12:13 pm
Standard watering can and rose.
One pours, one washes - you don't need a lot to get wet, stop pouring then lather up, rinse.
Change places. :wink:
Used to use this method in our old tent, just roll back ground sheet.
You could make a cubicle by fixing a cloth round Bongy's tailgate with magnets and pegging down.
