Air con cuts out in very hot weather
geoff46
Post by geoff46 » Thu Aug 13, 2020 11:45 am
Hi all, I’m having some intermittent air con problems and would appreciate some advice. Got a 2000 diesel face lift Bongo with climate control, located in St Albans. Under normal conditions the air con works fine, but when it gets hot outside, like now, the problem appears. It works fine when you first start up, but once the engine gets up to temperature the air con cooling cuts out. Blowers keep running but it’s just recirculating warm air. Coolant temp gauge sits happily at 11 o’clock (for what that’s worth) and no warning lights come on. Radiator fans come on as they should as soon as the air con is switched on. I’ve had the air con system checked to see if it needs re-gassing, which it doesn’t. I was also advised to check that the scavenger fan was working. It doesn’t seem to be coming on, but from what I’ve read that isn’t unusual. I’ve tested it by shorting the pins of the air temp sensor connector by the handbrake and it came on as it should. Leaving it running constantly didn’t stop the air con from cutting out. Any ideas? I am wondering if the air temp sensor has any role in governing the air con system in addition to the scavenger fan and thinking maybe should try replacing it? Thanks in advance for any help.
Re: Air con cuts out in very hot weather
Post by g8dhe » Thu Aug 13, 2020 12:00 pm
The scavenger fan has no involvement with the air con at all. The only sensor for the scavenger fan is the thermistor mounted under the handbrake poking in to the engine housing, it only comes on when the air above the engine gets hot, normally when the vehicle is static or slow moving and the air flow is insufficient to keep the temperature down.
As to the air con, not sure I have ever heard of a fault like that before, is the compressor continuing to run ? There is a belt that drives the spindle which then has a magnetically operated clutch to connect it the compressor itself, this is controlled by the climate control module along with the pressure sensor to make sure there is refrigerant in the system as well.
cwilliams255
Post by cwilliams255 » Thu Aug 13, 2020 12:54 pm
As the aircon works most of the time and everything is static except the compressor it does seem like the compressor clutch is maybe failing to engage in hot weather. It’s pretty easy to check as you should be able to hear / feel it engage when you turn AC on and off (at least in mine you can)
Only time I experienced something similar was due to a gas leak, was fine until a really hot day where it ended up below engagement value of sensor. However as you’ve had it checked then it seems unlikely - did they tell you how much gas was present?
geoff46
Post by geoff46 » Thu Aug 13, 2020 1:56 pm
Thanks for the info guys. I'll check out the clutch. I wasn't told how much gas was is the system, just that it wasn't a problem. I'll go back to the garage and see if they have a record of it.
Post by Northern Bongolow » Thu Aug 13, 2020 3:44 pm
You can usually improve things by checking the airflow through the condenser rad, mine was filled with weird Japanese dragon flies,they were all holding hands and blocking throughput of air,
Strip the front off the heater unit under the bonnet till you come to the condenser, clean out with a soft brush etc you will notice a difference.
Also check the front sensor on the dash, this has a little fan in it, it gets blocked, quick blow out can help.
geoff46
Post by geoff46 » Fri Aug 14, 2020 4:32 pm
Will do this also.
Regarding the clutch I tested it from cold yesterday. When switching the air con on and off you can hear a click from the compressor which I assume is the clutch engaging and disengaging. However once the engine was hot and the air con had stopped working then the click also stopped.
Post by g8dhe » Fri Aug 14, 2020 5:44 pm
Well other than checking the voltage on the connectors that would rather point to the problem or manually triggering the relay when its hot to see if its the ECU signal that is not operating it. The clutch solenoid is G3-03 lower left and the relay G3-02 by earthing the Yellow/White (Y/W) would cause the relay to operate, if it does and the clutch comes in then it would point to being back towards the ECU.
geoff46
Post by geoff46 » Sat Aug 15, 2020 4:39 pm
Thanks Geoff, I'd just like to check my understanding.
When the air con has stopped cooling:
1. Check the voltage on the connector at the compressor - if that's ok then the fault is likely to be the clutch solenoid
2. If not ok then earth Y/W wire at the relay. If the relay operates then the fault is likely to be the ECU, if it doesn't then the fault is likely to be the relay
Have I got it right?
A couple of stupid questions
1. The compressor connector is on the single wire running to the compressor over the top of alternator?
2. Where is the air con relay physically located? I think it's one of the 4 on the passenger side wing under the bonnet. I've had a good search online but can't find anything that shows which one it is.
I'll need the weather to improve before I can do this!
Thanks again.
Post by g8dhe » Sat Aug 15, 2020 5:01 pm
geoff46 wrote: Sat Aug 15, 2020 4:39 pm When the air con has stopped cooling:
Yes
Yes and check the next page on the diagrams, positions of each device shown on vehicle layout.
geoff46
Post by geoff46 » Mon Aug 17, 2020 4:22 pm
Found the relay. Just need to wait for the weather to improve then I'll do the testing. I'll let you know how I get on. Thanks for all the help so far.
geoff46
Post by geoff46 » Fri Aug 28, 2020 12:34 pm
Right, test done. When the aircon cut out there was still voltage at the connector to the compressor, so looks like faulty clutch solenoid. Do you know if these are serviceable (have found the diagram on Lush Projects), or am I best to get a new compressor? Thanks.
Post by g8dhe » Fri Aug 28, 2020 3:53 pm
I've not heard of anyone affecting a repair, a recent attempt on FB ended up with the compressor damaged in removing the clutch!
geoff46
Post by geoff46 » Fri Aug 28, 2020 9:21 pm
Ok, new it is. Update to follow.
Post by rita » Sat Aug 29, 2020 9:43 am
As a matter of interest was the system re gassed .
