Wiring through the bulkhead
loovic07
Post by loovic07 » Fri Jul 31, 2020 1:04 pm
Anyone have recommendations for getting wires through the bulkhead - both Battery positions?
cwilliams255
Re: Wiring through the bulkhead
Post by cwilliams255 » Fri Jul 31, 2020 1:38 pm
I’m sure you could certainly come up with a better solution but I’ve just put a sharp small screwdriver through the existing grommit and fed the wire through. The grommit is well shielded from water etc so I deemed this suitable, a bit of silicon could be used but the holes I made look suitable sealed just by the size of the wiring. I suspect that a lot have just done the same
Post by g8dhe » Fri Jul 31, 2020 1:49 pm
There are existing grommets as above both sides, on mine the nearside wasn't used at all. I usually wrap with self amalgamating tape just to ensure total waterproofing and it also ensures that any pull strain from the inside is absorbed by the grommet rather than pulling the cable thru further.
Rickster
Post by Rickster » Sun Aug 02, 2020 2:30 pm
I just use a scalpel blade to cut a cross in it, this method is a bit old skool but works.
