bongo cutting out
davied
bongo cutting out
Post by davied » Mon Jul 13, 2020 12:54 pm
hi guys,hope your all well. I have a problem with my 1997 v6 lpg/petrol bongo. the engine cuts out after a long run, usually when slowing down. when i try starting it again there is nothing, only when i leave it for at least 20 mins to cool down will it start again. the temp gauge is fine before it cuts out. it cuts out on lpg and petrol. it doesnt happen on every long run. I have seen previous related posts on forum but their bongo seems to start right away after cutting out, with mine there is nothing at all until it cools. hope you can help. davie
Re: bongo cutting out
Post by g8dhe » Mon Jul 13, 2020 2:38 pm
Could be a faulty ignition and spark system causing problems ? Check distributor, leads and spark plugs as a minimum.
davied
Post by davied » Mon Jul 13, 2020 3:17 pm
thanks, its booked into local garage on thurs,i`ll give them all the info i can.
Cabbos
Post by Cabbos » Thu Dec 23, 2021 5:19 pm
Hi I know this is an old post but how did you get on as my bongo is just started to do the same.
Thanks Del
Post by Bob » Fri Dec 24, 2021 9:47 am
Which engine do you have? 8)
Cabbos
Post by Cabbos » Fri Dec 24, 2021 11:27 pm
Mine is a 2.5 v6 petrol strange it was fine today, it had this problem before I brought it a month ago. The trader had fitted a new crankshaft sensor I've driven it with no problems from Manchester to kent it's been my daily driver so not sure now
sy53
Post by sy53 » Fri Jul 25, 2025 6:22 pm
Hello, I have a cutting out issue with my Bongo V6 2.5 petrol, I have been though everything checking and testing, Replaced the O2 sensor, crankshaft sensor, new ignition coil, new plugs and leads. But it still cuts out after about 45mins to 1 hour, once it cuts out, then it doesn't start again until cool. Can anyone help.
Post by g8dhe » Sat Jul 26, 2025 9:25 am
Another possible cause is the sensor inside the distributor https://www.ebay.co.uk/itm/143996874577 this has been reported a number of times as being a heat dependent problem. It fits below the rotor in the body itself with a plug on the outside for its connections.
