Error codes V6 2001
Bongold
Error codes V6 2001
Post by Bongold » Wed Jun 10, 2020 5:46 pm
After doing some work on resoldering some old connections, tidying various cables and switches, and replacing some dash bulbs. I now have a hold light flashing. I wired up an led and went through the Engine, ATX and ABS codes on the data port and only have errors on the ATX, which mirrors on the dash.
The codes are 21, 11 and 16 which I can't find info on. Any ideas please?
V6 2001
Re: Error codes V6 2001
Post by g8dhe » Wed Jun 10, 2020 7:03 pm
Try searching on the web for the full 4-digit version "mazda bongo error code P0021"
OR
its possible your codes are the 4-digit versions as it was around 2001/2002 that they changed over in which case you need to read the codes in that format and not the Ten's and Units format.
Bongold
Post by Bongold » Wed Jun 10, 2020 7:44 pm
As a four digit code it seems to be coming out as 1601. A web search leads me to this description:
P1601 Powertrain Control Module Communication Line To TCM Error
How on earth do I check this? It could possibly be a loose connection or something?
Post by Ian » Wed Jun 10, 2020 9:47 pm
Try this to reset the fault codes
Remove the wire from the negative terminals on all batteries (including leisure battery if installed) for at least 20 seconds.
Click on the brake pedal and release.
Re-connect negative battery terminal.
Start engine, and run for 3 minutes at 2,000 rpm idle.
Check all fault codes have cleared.
Bongold
Post by Bongold » Thu Jun 11, 2020 2:19 pm
Thank you for the instructions. The error codes have cleared so I will see how things go from now.
