12v outlet
Bongolia
12v outlet
Post by Bongolia » Sun May 10, 2020 11:03 am
Quickie.
NS rear 12v outlet. What current can I safely draw from it?
Re: 12v outlet
Post by g8dhe » Sun May 10, 2020 12:14 pm
The sockets themselves are rated and fused for 10Amps, but the wiring to the rear sockets is on the thin side so you will get a lot of voltage drop if you try to draw 10 Amps.
Bongolia
Re: 12v outlet
Post by Bongolia » Sun May 10, 2020 1:09 pm
Thanks Geoff
Roy748
Re: 12v outlet
Post by Roy748 » Fri May 15, 2020 4:24 pm
Not only is the live wire to the socket rated at around 5amps the negative wire is thinner than the live, so check and replace if this is the case.
I had a short from my stereo, which tripped out my folding mirrors and front cigarette lighter. Having isolated and replaced wires, the only earth wire I found melted was this earth wire at the rear socket.
