obd2 port RF diesel 2.0
pegrande
Post by pegrande » Thu May 07, 2020 4:51 pm
hi everyone, I've joined this group because of problems with the above subject. My Bongo (which is rebadged as Nissan Vanette) is from 2010 and I've bought it because of the fine engine. I am now in limp mode and that seems to be linked to the EGR. I do have an older style Mazda diagnose port (as stated in earlier posts here OBD1 ) but there are some cut wires obviously from a formerly connected OBD2 Port. Not sure why that would have been removed but its a fact.
Does anybody have a wiring diagram of the OBD2 port so I can reconnect???
Thanks in advance..... :wink:
Re: obd2 port RF diesel 2.0
Post by g8dhe » Thu May 07, 2020 5:22 pm
Welcome.
That sounds like the previous 3rd generation Bongo https://en.wikipedia.org/wiki/Mazda_Bon ... 80%931999)
Not sure we have much experience on those vehicles at all, most of the users here are dealing with the Mazda Friendee or Ford Freda.
Would be surprised that there was an OBDII port on the previous generation when it wasn't added to the Friendee until post 2002 (?).
Post by Bob » Thu May 07, 2020 5:39 pm
Sorry I can't help with your enquiry, but we have some very good people on here (as Geoff has shown) and you may get more answers.
Welcome aboard, and do enjoy the Forum. 8)
maxi_77
Post by maxi_77 » Sun May 10, 2020 11:28 am
I think this is a Bongo E series a very different beast to the Freindee we deal with.
White diesel Bongo
Post by Doone » Sun May 10, 2020 5:01 pm
There's a Nissan Vanette campervan group on Facebook thst may be able to help you. https://www.facebook.com/groups/1320740 ... ?ref=share
pegrande
Post by pegrande » Thu May 21, 2020 2:08 am
problem solved: Firstly there is an OBD 2 plug. My problem finding it was because it is on a detachable wiring loom that had been forgotten and it does not seem to share wiring with the Mazda / OBD1 plug.
But a funny descovery that might help others was the reason for the limp mode: I could narrow it down to some problem with accelerator / TPS. I did have several fault codes related to that. Now the electronic accelerator pedal has 2 potis, one linear with a falling curve and one rotating with a rising curve. Through trial and error I discovered that a little rubber disc/backstop had fallen out. There is some stuff online about how to calibrate that sort of pedal but that seems to be not necessary. This little rubber disc missing, about 12mm dia and 4mm high is all it needs :wink: to send the ECU in limp mode!!!
Post by Bob » Thu May 21, 2020 8:12 am
Well done. =D>
