Bongo v6 wont start when it rains
Stevejoy5
Post by Stevejoy5 » Tue Apr 28, 2020 11:38 am
hi guys
Just a quick one to see if anyone else has had same issue ? The bongo turns over but will not start. If its dry its fine but as soon as it rains it will not go for ages i have to end up putting jump leads on and eventually it will fire on1 then 2 3 and 4. Before i go digging any ideas??
Steve
Stevejoy5
Re: Bongo v6 wont start when it rains
Post by Stevejoy5 » Tue Apr 28, 2020 12:40 pm
Stevejoy5 wrote: Tue Apr 28, 2020 11:38 am hi guys
Just a quick one to see if anyone else has had same issue ? The bongo turns over but will not start. If its dry its fine but as soon as it rains it will not go for ages i have to end up putting jump leads on and eventually it will fire on1 then 2 3 and 4,5,6Before i go digging any ideas?? Im thinking distributor but i dont see how that can get wet were its located.
Steve
JulesMartin
Post by JulesMartin » Tue Apr 28, 2020 12:42 pm
Sounds like a bad case of damp. have you checked leads, coil etc for tracking or arcing? a good dose of WD40 all over the electrics may help.
Martin
Stevejoy5
Post by Stevejoy5 » Tue Apr 28, 2020 12:51 pm
No i havent but it seems odd that it could be getting wet given the location of leads and distributor.
Someone said there is a seal on distributor that maybe worn and allowing damp into cap.
Post by g8dhe » Tue Apr 28, 2020 2:52 pm
The distributor is in direct line of fire for road splash, it probably creeps into the distributor as vapour then on cooler mornings condenses inside to water and shorts out.
Try removing each lead and cleaning, check the spark plug well at the same time, often oil and muck will gather in the bottom, the sparkplug connector can also suffer these were off of mine;
after cleaning each lead, clean the outside of the distributor cap at least, then spray with WD40 to help with the water dispersal.
Stevejoy5
Post by Stevejoy5 » Tue Apr 28, 2020 9:11 pm
Thanks geoff its strange because i havent drove it since jan or feb shes just been in drive and i start her every now and then but come across this issue every time its wet outside. When weather drys up i will have a look and see what i can find from your advice.
Stevievee
Post by Stevievee » Fri Jun 19, 2020 5:30 pm
Just reading through some older posts and came across this. Could it be a blocked drainage hole (channel at bottom of the windscreen) therefore overflowing onto some of the electrics?
Post by g8dhe » Fri Jun 19, 2020 6:24 pm
Unlikely it overflows over the air con system nothing to do with the engine electrical items at all.
Stevievee
Post by Stevievee » Fri Jun 19, 2020 8:36 pm
g8dhe wrote: Fri Jun 19, 2020 6:24 pm Unlikely it overflows over the air con system nothing to do with the engine electrical items at all.
Just shows what I know.... stick to pushing pens Steve!, :D
