Leaking rear diff
tay
Leaking rear diff
Post by tay » Thu Mar 12, 2020 4:46 pm
Hi all,my rear diff is leaking, 2.5 diesel 4x4.Can't seem to find anyone that does a replacement seal.tried all the usual suspects. Am i right in thinking that I am going to have to change the complete rear axle to remedy this,or can anyone shed any light on a solution to this. I've changed oil checked the breather on top.
i chose not to choose life ....i chose a bongo instead
Re: Leaking rear diff
Post by Bob » Thu Mar 12, 2020 5:35 pm
I can't think you need a replacement axle assembly because of a leaking seal.
Is it where the drive enters, either side where the half shafts exit, or the rear of the casing?
This is just one, but should link to other seals:
https://mazdabongo.com/product/mazda-bo ... n5EALw_wcB
Post by g8dhe » Thu Mar 12, 2020 7:51 pm
I bought the two pairs of axle seals from BongoSpares and had my garage fit them. I would imagine they also do the other seal as well, standard seals.
cwilliams255
Post by cwilliams255 » Thu Mar 12, 2020 11:04 pm
Where is it leaking? In center where diff bolts to axle or out of half shafts near brakes? If it’s the former, draining the oil, splitting from axle and applying some gasket sealant will sort that out. If it’s the latter will probably need new seals as they are delicate and easily damaged from what I remember
Post by rita » Fri Mar 13, 2020 2:37 am
tay wrote: Thu Mar 12, 2020 4:46 pm Hi all,my rear diff is leaking, 2.5 diesel 4x4.Can't seem to find anyone that does a replacement seal.tried all the usual suspects. Am i right in thinking that I am going to have to change the complete rear axle to remedy this,or can anyone shed any light on a solution to this. I've changed oil checked the breather on top.
Hi,I dont understand why you changed the oil when you have an oil leak..?
Is the leak coming from the pinion seal or the diff case gasket ?
tay
Post by tay » Fri Mar 13, 2020 7:05 am
It's leaking from where the prop enters the diff case in the centre, local garage said it can't find part anywhere, tried several bongo garages to no avail
Post by Bob » Fri Mar 13, 2020 11:44 am
Post by rita » Fri Mar 13, 2020 11:58 am
You should be able to get the pinion seals from Mazda Part No R00127165
tay
Post by tay » Fri Mar 13, 2020 4:53 pm
Thanks for the replies
