New big end shells ??
mickc
Post by mickc » Tue Mar 03, 2020 2:41 am
My 96 diesel motor has 280k kms on the clock and the bottom end seems to knock above 3000rpm, I thought about replacing the big end shells before any scoring/damage occurs to the crank. The engine gives good power, doesn't consume oil.
At lower revs the motor sounds fine so I thought a bit of preventitve maintenance would be in order, is it a job that can be done without too many problems?
Any comments appreciated, thanks.
Re: New big end shells ??
Post by rita » Tue Mar 03, 2020 12:11 pm
Have you checked the oil pressure,and when was the oil filter replaced .
mickc
Post by mickc » Tue Mar 03, 2020 4:33 pm
rita wrote: Tue Mar 03, 2020 12:11 pm Have you checked the oil pressure,and when was the oil filter replaced .
Thanks for the reply rita, oil and filter are changed every 6 months at Wheelquick, my van does 8-10k miles per year on average, how to check the oil pressure I have no idea.
Post by rita » Tue Mar 03, 2020 9:29 pm
mickc wrote: Tue Mar 03, 2020 4:33 pm
The oil switch is removed and a oil gauge is fitted.,the oil pressure can be adjusted but I would get the advice from an experienced mechanic.
Post by Bob » Tue Mar 03, 2020 9:57 pm
If you use a T-piece you can fit the gauge and retain the warning light. :wink:
Post by rita » Wed Mar 04, 2020 11:06 am
Bob wrote: Tue Mar 03, 2020 9:57 pm If you use a T-piece you can fit the gauge and retain the warning light. :wink:
The gauge used is a test gauge , after the test you simply refit the switch.
