Diagram for aft
scottishbubbles
Diagram for aft
Post by scottishbubbles » Sat Feb 29, 2020 6:44 am
Is there a technical diagram for the workings of the aft on the site cant find one. Thanks
Re: Diagram for aft
Post by g8dhe » Sat Feb 29, 2020 10:34 am
The nearest to a diagram is http://www.lushprojects.com/bongopartsm ... 2of02.html
Basically there is a Teleflex cable fixed to the slider in the roof which comes down to its own side drive motor where it is push/pulled by a crown/bevel gear, it then continues around the back of the AFT to the other side where it passes over the other motor in order to keep both motors in sync and then the free end passes up the other channel but is not attached at all.
